I'd like to be able to identify polygons from one dataset that touch a polygon from a different dataset then tag that the polygon touches on one (or multiple( edges.
  • Mar 8, 2022 4:14 PM UTC
  • 102 views
jez
Participant
Hi.
The image below is an extract from a much larger dataset. The image shows:
  • Vegetation as the green polygon
  • Buildings as hollow fill polygons
The polygons are on two different datasets and have been built in such a way that the edge between the two polygons are 'edge to edge'.
I need to be able to identify those buildings that 'touch' the vegetation polygon which I have identified with the red dot.
imageIt's been a while since I had to use this type of analysis and after searching the FME forum I'm still stuck. I guess could be overcomplicating my thought process. I know MapInfo has the functionality to do this but wanted to learn FME's approach.
Any help would be very much appreciated.
@jez​ FME has several spatial join (webinar) tools. Merging or Joining Spatial Data is a good place to start, as well as the webinar link. I think I'd jump to the SpatialRelator but success will depend on how clean the data is.
jez
Participant
  • Participant
  • Mar 9, 2022 7:24 AM UTC
I knew there would be an appropriate transformer, marketsafe you are a star! The SpatialRelator with the Spatial Predicates to Test set to "Requestor OGC-Touches Supplier" works perfectly. Thankfully the data is in an excellent condition and this works perfectly.
