I am getting issue for fme floating license.
  • September 23, 2020
  • 8 replies
  • 265 views
Please help me regarding issue in float the license in another machine.
My floating license is up in one machine and static IP assign to it. When we assign floating license in another machine we are getting error regarding port. I ask network team ,all port open for server.
Safe has published a very thorough troubleshooting guide for the floating license server here:
https://community.safe.com/s/article/floating-license-troubleshooting
I highly recommend starting out there, it covers the most important aspects.
You may also want to consider overriding the default port range, some firewalls have an easier time with a fixed port:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Specifying_Floating_License_Server_Ports.htm
  • September 24, 2020
Hi Team , I tried with assigning port number in license file as below but its not able to up the server as error Port is not reachable in license file.
SERVER servername 000c290de0df 27001
VENDOR safe PORT=1700
Is this correct way to define port number in license file?
We have tested on the below test cases to float the license from FME Server Machine .
a)17.76.43.109(Static IP) to 17.76.xx
b)17.76.43.109(Static IP) to VPN
As we are able to install the FME application , up the server but was not successful in floating the license in any of the above cases.
Below is diagnostic details.
 Diagnostic Details :
  2020-09-23 16:23:13 FME Licensing Assistant specified the server as 17.76.43.109 (and port not specified) so any existing license files will be ignored
  2020-09-23 16:23:13 Checking for environment variables that may affect the connection to a floating license server
  2020-09-23 16:23:13 Checking whether an IP address can be determined from the server
  2020-09-23 16:23:13 Server 17.76.43.109 resolves to IP address 17.76.43.109
  2020-09-23 16:23:13 Checking network connectivity by sending a 'ping' to the server
  2020-09-23 16:23:14 Server 17.76.43.109 (17.76.43.109) responded to a ping, indicating there is a network connection to the server
  2020-09-23 16:23:14 Checking network connectivity by opening a TCP port on the server
  2020-09-23 16:24:30 Could not open standard port 27000 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:25:46 Could not open standard port 27001 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:27:02 Could not open standard port 27002 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:28:18 Could not open standard port 27003 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:29:34 Could not open standard port 27004 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:30:51 Could not open standard port 27005 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:32:07 Could not open standard port 27006 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:33:24 Could not open standard port 27007 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:33:24 Could not open standard port 27008 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:33:24 Could not open standard port 27009 on server 17.76.43.109 (17.76.43.109)
  2020-09-23 16:33:24 No port was specified, and no standard licensing ports could be opened on server 17.76.43.109 (17.76.43.109).  Please have your systems administrator check that your license service is running (standard ports are between 27000 and 27009), and that you have network connectivity to it.  If you have confirmed that your license service is running, you may wish to investigate further by using the server-side diagnostics tool available from http://fme.ly/FloatingLicenseHelp
  2020-09-23 16:33:24 For floating license service troubleshooting help, visit http://fme.ly/FloatingLicenseHelp
Try skipping the 27001 port number, only use the port number on the second line, e.g.
From FME Desktop connect to that specific port when specifying the license server, e.g.
servername:1700
That works for me in most cases.
Hi David,
It's also not working for me. License is up on server machine , but when we are trying to floating the license on client machine, it's not working.
From FME Desktop connect to that specific port when specifying the license server, I used as below
servername:1700
All port are open in server machine.
020-09-25 00:34:04 The FME license has failed, so FME will now attempt some diagnostics for the floating license
2020-09-25 00:34:04 Checking for a floating license file in the locations: /Library/FME/2020.1/licenses/fme_license.dat "/Users/rachinjain/Library/Application Support/FME/Licenses/fme_license.dat" "/Users/rachinjain/Library/Application Support/FME/Licenses/fme_license.dat"
2020-09-25 00:34:04 Found a floating license file: '/Users/rachinjain/Library/Application Support/FME/Licenses/fme_license.dat'
2020-09-25 00:34:04 Reading the floating license file: '/Users/rachinjain/Library/Application Support/FME/Licenses/fme_license.dat'
2020-09-25 00:34:04 License file specifies server # 1 as 17.76.35.125 (and port not specified)
2020-09-25 00:34:04 FME Licensing Assistant specified the server as 17.76.35.125 using port 1700 so any existing license files will be ignored
2020-09-25 00:34:04 Checking for environment variables that may affect the connection to a floating license server
2020-09-25 00:34:04 Checking whether an IP address can be determined from the server
2020-09-25 00:34:04 Server 17.76.35.125 resolves to IP address 17.76.35.125
2020-09-25 00:34:04 Checking network connectivity by sending a 'ping' to the server
2020-09-25 00:34:04 Server 17.76.35.125 (17.76.35.125) responded to a ping, indicating there is a network connection to the server
2020-09-25 00:34:04 Checking network connectivity by opening a TCP port on the server
2020-09-25 00:34:04 Could not open user-specified port 1700 on server 17.76.35.125 (17.76.35.125). Please check with your systems administrator that you have the correct port, your license service is running, and that you have network connectivity to it
2020-09-25 00:35:25 Could not open standard port 27000 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:25 Could not open standard port 27001 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27002 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27003 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27004 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27005 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27006 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27007 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27008 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Could not open standard port 27009 on server 17.76.35.125 (17.76.35.125)
2020-09-25 00:35:26 Port 1700 was specified, yet no specified or standard licensing ports could be opened on server 17.76.35.125 (17.76.35.125). Please have your systems administrator check that your license service is running on the correct port (standard ports are between 27000 and 27009), and that you have network connectivity to it. If you have confirmed that your license service is running, you may wish to investigate further by using the server-side diagnostics tool available from http://fme.ly/FloatingLicenseHelp
2020-09-25 00:35:26 For floating license service troubleshooting help, visit http://fme.ly/FloatingLicenseHelp
  • September 25, 2020
Hi David, Please help me in floating the license in another machine. I am getting same port error with all senerio.
I tested all senerio but I am not able to connect the license in client machine. I check with port number also.
Is any license file we have to copied in client machine before floating the license?
or any valid Vendor port number which can work for me. I try with port number 1700 at vendor side.
I suggest that you contact a support technician at your FME reseller/partner (i.e. where you bought your FME license), they should be able to provide better support in such cases.
jovitaatsafe
Forum|alt.badge.img+11
Hi @rachinjain​, sorry to hear that the licensing hasn't been going as smoothly as you had hoped. I see you have a case in progress (C166004) and that our codes team is on it. You can expect to hear back on it shortly!
  • September 29, 2020
@jovitaatsafe​ , Yes my C166004 - Safe Software Support Case Created and its in progress.
They asked to run and share to them below details.
1) We  want to ensure that the floating license server is up and running properly, please follow the below steps in a terminal window:
  • cd ~/Desktop/fme-flexnet
  • enter the command to shut down the license service: ./lmutil lmdown -c safe.lic -q
  • then to start up the license service: ./lmgrd -c safe.lic -l safe.log
  • then to check the status of the license service to ensure it is running: ./lmutil lmstat -a
  • Please send the contents of the terminal window
Contents of the terminal window:-
A)Shut down the server:-
C02T704RGG7N:fme-flexnet pt_27$ ./lmutil lmdown -c safe.lic -q
lmutil - Copyright (c) 1989-2018 Flexera. All Rights Reserved.
  Port@Host      Vendors
1) 27000@C02T704RGG7N safe
 8:42:17 (lmgrd) SHUTDOWN request from pt_27 at node C02T704RGG7N
 8:42:17 (lmgrd) lmgrd will now shut down all the vendor daemons
 8:42:17 (lmgrd) Shutting down safe pid=50440 because of signal 15
 8:42:17 (safe) (@safe-SLOG@) ===============================================
 8:42:17 (safe) (@safe-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
 8:42:17 (safe) (@safe-SLOG@) Time: Tue Sep 29 2020 08:42:17 IST
 8:42:17 (safe) (@safe-SLOG@) Request processing time, when, #concurrent clients, client info (user, node, FD)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:42:17 IST,#5,(pt_27,C02T704RGG7N,26)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:41:45 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:41:39 IST,#4,(pt_27,C02T704RGG7N,25)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:39:45 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:39:39 IST,#4,(pt_27,C02T704RGG7N,25)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:37:46 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:37:40 IST,#4,(pt_27,C02T704RGG7N,25)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:35:46 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:35:40 IST,#4,(pt_27,C02T704RGG7N,25)
 8:42:17 (safe) (@safe-SLOG@) 00000000 ms at Tue Sep 29 2020 08:33:46 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 16:38:17 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 15:56:17 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 15:24:18 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 15:52:17 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 14:26:50 IST,#3,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 14:28:11 IST,#3,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 15:30:18 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 14:28:17 IST,#3,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 14:28:19 IST,#3,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) 00000001 ms at Mon Sep 28 2020 15:00:19 IST,#4,(pt_27,C02T704RGG7N,24)
 8:42:17 (safe) (@safe-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
 8:42:17 (safe) (@safe-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
 8:42:17 (safe) (@safe-SLOG@) In-house operation time, when, #concurrent clients
 8:42:17 (safe) (@safe-SLOG@) === Active Connections Info ===
 8:42:17 (safe) (@safe-SLOG@) Peak active connections #5 attempted at Tue Sep 29 2020 08:42:17 IST
 8:42:17 (safe) Shutdown requested.
 8:42:17 (safe) daemon shutdown requested - shutting down
 8:42:17 (safe) IN: "FME" pt_27@C02T704RGG7N (SHUTDOWN)
 8:42:17 (safe) IN: "professional" pt_27@C02T704RGG7N (SHUTDOWN)
 8:42:17 (lmgrd) Shut down FlexNet safe license server system on machine C02T704RGG7N
 8:42:17 (lmgrd) EXITING DUE TO SIGNAL 15
  1 FlexNet License Server shut down
B)status of the license service:-
C02T704RGG7N:fme-flexnet pt_27$ ./lmgrd -c safe.lic -l safe.log
C02T704RGG7N:fme-flexnet pt_27$ ./lmutil lmstat -a
Flexible License Manager status on Tue 9/29/2020 09:35
License server status: 27000@C02T704RGG7N
  License file(s) on C02T704RGG7N: /Users/pt_27/Desktop/fme-flexnet/safe.lic:
C02T704RGG7N: license server UP (MASTER) v11.16.2
Vendor daemon status (on C02T704RGG7N):
   safe: UP v11.16.2
Feature usage info:
Users of FME: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of FME_GUI: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of national: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of basic_raster: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of segy_reading: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of segy_writing: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of professional: (Total of 5 licenses issued; Total of 0 licenses in use)
Users of fmeobjects_reproject: (Total of 5 licenses issued; Total of 0 licenses in use)
I am waiting for response from codes team.
