HttpCaller SSL Connect Error
  • Feb 25, 2021 1:07 PM UTC
  • 98 views
I want to access the api using HttpCaller. (https://api.ieo.org.tr/)
works fine on my own computer. but i am getting ssl error on windows server.
Chrome can open the page.
How HttpCaller sends the request.. What adjustments should I make?
Thank you
  • Feb 25, 2021 2:05 PM UTC
Have you tried setting Verify SSL certificates to NO under the client settings in the HTTPCaller?
  • Feb 25, 2021 2:12 PM UTC
David;
Yes I tried. But I failed
  • Feb 25, 2021 2:15 PM UTC
David;
It works just fine for me and I cannot see anything obviously wrong with the certificate.
You should probably get in contact with your IT services and have them check for proxy or policy issues on your server.
  • Mar 12, 2021 6:27 AM UTC
Hi David,
thank you for your suggestions.
I still could not solve the problem. fme fails even though POSTMAN works properly.
I can send a Chrome request.
