HttpCaller - POST - How to add UserName and Password within BODY
  • May 23, 2023 8:45 AM UTC
  • 297 views
juanmahere
Forum|alt.badge.img+15
Hi FME lovers,
I'm getting blocked when trying to access this website, via POST:
https://lastkajen.trafikverket.se/api/Identity/Login
Using HttpCaller from FME 2022.2, I have:
HttpCaller settingsBut, no luck, a http_status_code = '400' is sent.
On the other hand, I've had no issues using Postman:
postman
I guess I'm not filling well the HttpCaller settings, right?
Thanks!
Best answer by nielsgerrits
I think the body in the HTTPCaller is incorrect. Try
UserName=xxx&Password=xxx
nielsgerrits
Forum|alt.badge.img+67
  • May 23, 2023 8:51 AM UTC
juanmahere
  • May 23, 2023 9:04 AM UTC
Thanks @nielsgerrits​  for your quick reply,
I've tested with:
  • UserName=XXX&Password=XXX
and works perfectly, thanks for the tip!! ;)
hkingsbury
Forum|alt.badge.img+73
  • May 23, 2023 8:11 PM UTC
To build on @nielsgerrits​ response, it looks like the API your using requires the input encoded as a form (which is what Niels gave you). What you initially had is JSON, so for some APIs, JSON encoding is valid (you'd need to make sure you set the content type to JSON in those cases)
nordpil
Forum|alt.badge.img+12
  • Jul 15, 2024 10:53 AM UTC
FYI - I created a web connection and published to the hub for authorization for this service:
https://hub.safe.com/publishers/nordpil/web-connections/trafikverket-lastkajen-api
