Http certificate error on FME Desktop
  • Mar 15, 2022 9:06 AM UTC
  • 120 views
When I try to run the AWS DynamoDB reader in FME desktop i Get the error.
ERROR |com.amazonaws.SdkClientException: Unable to execute HTTP request: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I tried following what this question says:
https://community.safe.com/s/question/0D54Q000080hbz0SAA/httpcallser-ca-certificate?t=1647334797980
Connecting to dynamo DB using same credentials using CMD workes fine and uploading Workspace to FME Server also runs fine. Only problem is on local Desktop version 2021.2.
I have tried to add the certificate to Windows Certificate Store but no luck. Any ide what might help?
Best answer by samuel.wsp
This was solved after updating FME to version 2021.2.4.
  • Mar 23, 2022 9:24 AM UTC
Adding log file
  • Mar 29, 2022 10:06 AM UTC
