How will I make the Inspector to automatically start?
  • Mar 24, 2021 2:49 PM UTC
  • 5 replies
  • 176 views
I thought that with a Inspector attached in the workspace the ​FME data Inspector would automatically start when the run is completed, but nothing happends? How can that be?
nielsgerrits
Forum|alt.badge.img+67
You probably have the "visual preview" window open and or the checkbox "Inspect with Data Inspector when Visual Preview window closed" unchecked?
FmeOptions
Thanks! It was unchecked . But check it didn't make any difference ....
Forum|alt.badge.img+54
  • Mar 24, 2021 3:27 PM UTC
And the visual preview window is closed as well?
Yes, it is closed. Is the visual preview window ment to work in a simular way? Cause I cant manage to see anything there either?
nampreetatsafe
Forum|alt.badge.img+14
Yes it should be default go to the visual preview. What version and build number of FME are you using (in workbench go to Help > About FME)?
