Please post a log of your errors
Ok I will do when I com home Jus a moment :)
Here is the errors:
LAS reader: Could not read 340000 byte(s) from file 'D:\\NTNU\\Bachelor\\Cloude Compare\\Punktsky_V02\\Hus 2\\Hus_cloud_V02.las'. Data read from this file may be corrupt
FFS writer: Failed to get block of 10000 points starting at index 0
LAS Feature Recorder -1 2147549212 (RecorderFactory): Failed to write feature data to `C:\\Users\\gunna\\AppData\\Local\\Temp\\wb-cache-las2shapefile-ezrant\\Main_LAS -1 28 -1 0 91cb1e375aa5d5ea70e79234898778d9fd39538b.ffsupdating'
Translation FAILED with 4 error(s) and 0 warning(s) (0 feature(s) output)
I have the LAStools that I downloaded from Rapidlasso and my settings are like this:
Hello I checked the spesefic lasfile and it is actely corrupt so I tryed a lasfile that was working in CC and it also worked in FME :D
