How to use LAStools.lasnoise.
  • Apr 1, 2021 2:29 PM UTC
  • 5 replies
  • 120 views
Hello
I have problem to get LAStools.lasnoise to work at all.
I am reciving a lot of error.
Howe is the right way of set this up?
caracadrian
Forum|alt.badge.img+23
  • Apr 1, 2021 2:35 PM UTC
Please post a log of your errors
  • Apr 1, 2021 3:01 PM UTC
Ok I will do when I com home Jus a moment :)
  • Apr 1, 2021 4:21 PM UTC
Here is the errors:
LAS reader: Could not read 340000 byte(s) from file 'D:\\NTNU\\Bachelor\\Cloude Compare\\Punktsky_V02\\Hus 2\\Hus_cloud_V02.las'. Data read from this file may be corrupt
FFS writer: Failed to get block of 10000 points starting at index 0
LAS Feature Recorder -1 2147549212 (RecorderFactory): Failed to write feature data to `C:\\Users\\gunna\\AppData\\Local\\Temp\\wb-cache-las2shapefile-ezrant\\Main_LAS -1 28 -1 0 91cb1e375aa5d5ea70e79234898778d9fd39538b.ffsupdating'
Translation FAILED with 4 error(s) and 0 warning(s) (0 feature(s) output)
  • Apr 1, 2021 4:25 PM UTC
I have the LAStools that I downloaded from Rapidlasso and my settings are like this:
LAStools
  • Apr 2, 2021 10:09 AM UTC
Hello I checked the spesefic lasfile and it is actely corrupt so I tryed a lasfile that was working in CC and it also worked in FME :D
