How to use FTPCaller with ftps:// port 21 and implicity
  • May 23, 2022 2:00 PM UTC
  • 6 replies
  • 280 views
Hello,
I am supposed to solve the following problem with FTPCaller.
I need to call ftps://hostname using port 21 (implicitl FTP).
The FTPCaller help says the following:
"The transformer will use the explicit mode in the following cases:
The URL begins with ftpes: ftpes://hostname/path
The URL begins with ftps but also sets the port to 21: ftps://hostname:21/path"
How can I call ftps implicit with port 21 in FME?
It works fine with FileZilla.
Thanks, Zoran
hkingsbury
Forum|alt.badge.img+73
  • May 23, 2022 10:58 PM UTC
What error do you get when making the request over port 21?
  • May 24, 2022 5:48 AM UTC
The error is "FTP info: connect to xxx.xx.xxx.xx port 990 failed: Timed out
FTP info: Failed to connect to hostname port 990 after 21047 ms: Timed out
FTP info: Closing connection 0
FTP/FTPS/SFTP transfer error: Timeout was reached".
I think the problem is the combination port 21 and implicit.
hkingsbury
  • May 24, 2022 8:36 PM UTC
Based on the above you're trying to connect over port 990 but you're saying its only open on port 21?
What port are you specifying for the URL?
  • May 25, 2022 8:53 AM UTC
Sorry, my mistake.
I tried alredy also port 21 and the error is:
"Using explicit FTPS for hostname 'hostname' because the URL protocol is ftpes, or because the protocol is ftps and the port is 21
FTP info:  Trying xxx.xx.xxx.xx:21...
FTP info: Connected to hostname (xxx.xx.xxx.xx) port 21 (#0)
FTP info: server response timeout
In FTPCaller I can't switch the method from explicit to implicit.
FTPCaller uses automaticly explicit as metod with ftps:// and port 21.
hkingsbury
  • May 26, 2022 12:25 AM UTC
Sorry, my mistake.
You may need to look at using something like python to make your requests in this instance. It may also pay to submit a suggestion to allow the manual override of the ex/implicit - https://community.safe.com/s/bridea/acideasULT__brIdea__c/00B4Q00000AWlEVUA1
  • Jun 16, 2022 11:38 AM UTC
Sorry for late answer!
We solved the problem as we changed the protocol from ftps to sftp.
FME works fine with sftp.
Thank you for your support.
