How to use FME server app to edit XML data
  • Nov 3, 2020 4:01 PM UTC
  • 0 replies
  • 29 views
aguan
Forum|alt.badge.img+11
I just installed FME server 2020.1 in the hope to use the Server App functionality. One example comes up quickly. I have a XML file that I want to use FME server app to edit a few elements. The flatten elements are shown in the attached image. I want to present this in the server app as some kind of table. The label column is static and each cell of the other two columns either as a free text entry or a drop down choice. The free text entry and dropdown can be published FME parameters. The initial free text entry and the drop down choice is populated from the XML file, but the users can enter or select their own choice. The have a Save button to save the results back into the XML file. Is this possible to do this in the Server App?
