I have previously downloaded (using SharePointOnlineConnector)a file to my local PC storage, and I know that it is possible to use an S3Connector to upload attributes or files, but, how can I directly upload a file from Sharepoint to FME Server folder in the same Workspace without storing it at C:/?
How to upload a file from Sharepoint to an FME Server folder location?
Best answer by markw
Hi @armando_amador, you'll want to use the SharePointOnlineConnector and download the file as an attribute. The FMEServerResourceConnector can upload that attribute as a file (set Source > Upload > Attribute + Attribute To Upload as File). I'd also suggest experimenting a bit with the Folder ID and Upload with File Name parameters to understand the formatting before using attributes/parameters here (if you plan to). Let me know if this works for you!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
