How to trigger 'emailer' AFTER the Writer has finished?
  • Apr 5, 2022 12:12 AM UTC
  • 206 views
benvk
Forum|alt.badge.img+8
I have a scenario where I have a HTML report generator, it saved the report on a local disk.
Once this HTML report is saved I then wish to send an email with the HTML report as an attachment, but as the Writer doesn't have an output port, I cannot trigger the emailer this way. How do I tell the emailer to run once the Writer has finished?
Best answer by ctredinnick
Use a FeatureWriter transformer instead of a regular writer. It has a Summary port which allows the workflow to continue after writing. It also outputs on it a _dataset attribute which will be the filepath of the html file, so you can reference that directly in the Emailer.
ctredinnick
Forum|alt.badge.img+22
  • Apr 5, 2022 12:49 AM UTC
benvk
  • Apr 5, 2022 1:07 AM UTC
Thank you!
