How to replace text in dwg with help of xls spreadsheet
  • Jun 13, 2023 6:22 AM UTC
  • 9 replies
  • 284 views
proteve
Forum|alt.badge.img+4
How can I replace different texts in a dwg file with the help of pairs of search/replace data from 2 columns in an xls table?
Forum|alt.badge.img+63
You can use a DatabaseJoiner, FeatureMerger or FeatureJoiner to join the Excel data to your DWG and then replace the acad_text_string attribute with the value from Excel.
proteve
  • Jun 13, 2023 9:36 AM UTC
if i understand correctly all these suggestions assumes i have an attribute to join them. i have only a table with 1st column for text to search and 2nd column with the replace value.
Correct, your DWG texts will have a (potentially hidden) acad_text_string attribute containing the text, you can join on that.
proteve
  • Jun 13, 2023 10:31 AM UTC
thats true but that is not the same as the 1st column. 1st column of the table might contain the entire text or parts of the text i need to replace
Aha, that changes things. Can you post a sample?
proteve
  • Jun 13, 2023 12:19 PM UTC
here, i've attached a simple example.
proteve
  • Jun 13, 2023 12:20 PM UTC
another try for the xls
I think you would first need to decide what you want to do with partial or fuzzy matches. If it's a simple 1-to-1 match you can use the method I described earlier but for anything else you'll need to work out those rules first.
proteve
  • Jun 13, 2023 12:48 PM UTC
thats the problem. i have parts of text to search and replace. thats why i can't match by attribute. so it's not 1 to 1. i have from 100 to 500 texts in dwg (not unique) and i need to replace them with the matching values from xls file.
