How to replace decimal comma to dot to attribute value?
  • December 14, 2022
  • 500 views
This is probably very trivial topic but I cannot get the correct result from this:
@ReplaceString(@Value(ATTRIBUTE),,,.)
So idea would be to change e.g input value 1,6 to 1.6.
Or should I change some FME attribute value to have decimal separator as . instead of , ?
EDIT:
I get it working by this workaround. Maybe there's is some fancier solution image
Best answer by tomfriedl
@ReplaceString(@Value(test),",",".",caseSensitive=TRUE)
or
Transformer StringReplacer
tomfriedl
Forum|alt.badge.img+13
  • December 14, 2022
or
