How to read/write ODS files? Thanks
  • Nov 17, 2020 7:52 PM UTC
  • 293 views
farfar
Forum|alt.badge.img+12
@farfar​ are you referring to Apache OpenOffice suite spreadsheets?
farfar
  • Nov 18, 2020 7:39 AM UTC
Yes.
and using fme desktop for windows.
@farfar​ Sorry - at this point FME doesn't support Open Office. Please vote on this Idea and add any comments on your use case.
OpenOffice Calc does support export to Excel XLSX format and FME can read that. Also, ODS is based on XML, so perhaps FME's XML reader might be able to return the data you need, but that is obviously a more complicated approach.
  • Apr 4, 2023 10:10 AM UTC
Hi, you should use LibreOffice or OpenODS. Both run great with this type of file.
