How to read and practice based on FME document
  • Sep 14, 2018 3:52 PM UTC
  • 55 views
Hi there,
I try to learn FME, start from parameters, then I cannot find information that the document instructed, how to start my learn, see below one image. Thank you.
  • Sep 14, 2018 3:58 PM UTC
You need to expand the transformer parameters first and then right-click on one of them. Does this example screenshot explain it better?
Here's an alternative way to do the same thing:
Hi @allensong,
Rather than right clicking on the Transformer name itself you will need to expose the list of parameters belonging to that transformer. Right click on the single parameter that you would like to create a user parameter for and then the option should appear:
  • Sep 14, 2018 4:04 PM UTC
Thank you for quick response, I found it, really appreciate.
