How to Make Sure a Python Caller ran First and Finish the job before Starting Other Part of Script
  • Mar 20, 2023 8:16 PM UTC
  • 6 replies
  • 105 views
fmelearner
Forum|alt.badge.img+3
I have a disconnected Python Caller which is suppose to do some data cleaning in target dataset before Reading data from source and writing them into Target
Can you please let me know how I can make a sequence here before reading the data from source to ran and do the job of Python Caller First?
I tried to connect/put the Python caller before Reader but as you know where is no way to add it before reader , out of the box
Thanks
Best answer by hkingsbury
You need to connect the output port of the python caller to the initiator port of the feature reader
hkingsbury
Forum|alt.badge.img+73
  • Mar 20, 2023 8:22 PM UTC
Use the output of your python caller to trigger a feature reader. Replacing the reader with this feature reader will then only read the source data once the python is finished
fmelearner
  • Mar 20, 2023 8:55 PM UTC
Thanks for quick reply hkingsbury but can you please let me know where I can set the output of python caller to trigger a feature reader?
imageWhen I click on Output what I am seeing is this window without any option to select the reader
hkingsbury
  • Mar 20, 2023 9:10 PM UTC
  • Mar 21, 2023 9:18 AM UTC
+1 for the answer by @hkingsbury​ . I'll just add that you probably want to add a Creator before the PythonCaller, in case that isn't obvious.
hkingsbury
  • Mar 21, 2023 6:46 PM UTC
Good point 😛
fmelearner
  • Mar 21, 2023 6:54 PM UTC
Thank you guys both, and you are right David, Creator is needed too
