How to Linear Pattern a line with cell pattern when writing to a V8 DGN?
  • Sep 27, 2021 1:50 PM UTC
  • 108 views
I am converting ArcGIS data into a V8 DGN file and need to linear pattern a line with an existing cell. I see where you can set the igds_class to 5 (LINEAR_PATTERNED). However, I do not see any options to set the active cell to be a pattern, so the line does not appear in the DGN file. Is linear patterning supported in FME 2020.0.2.1?
muzhnasto
Forum|alt.badge.img+12
  • Nov 11, 2021 4:38 PM UTC
Hello. Perhaps you need to create a dgn in microstation with line samples and use this file as a seed file
