How to keep Raster Replacer from rotating photos?
  • Jun 15, 2021 3:37 PM UTC
  • 164 views
I have attachments stored as blobs in an Esri File Geodatabase that I am using RasterReplacer to save them as JPGs. When viewing the photos through ArcMap the orientation is correct. However once they run through FME and RasterReplacer saves them as JPGs, some of them are up side down. Anybody have any thoughts on this?
hkingsbury
Forum|alt.badge.img+73
  • Jun 16, 2021 11:32 PM UTC
Is there an orientation or rotation applied to them in ArcMap that need to be applied in FME?
  • Jun 23, 2021 2:31 PM UTC
Thank you for your reply. I do not believe so but have not come up with a firm answer. These photos were collected using Collector and also show up in the correct orientation in ArcGIS Online.
Also, if I save/download them manually from ArcMap or ArcGIS Online the orientation is correct.
