How to group attributes and generate group id based on 2 fields
  • Dec 15, 2022 1:49 PM UTC
  • 177 views
Group ID should start from 1 for each unique Attribute 1 value and the smallest value of Attribute 2 for each Attribute 1 value should get it as follows:
Best answer by dustin
Did you really get Counter to start from 1 for each attribute1 value?
Ahh, one small correction. I have attached the workspace. The group by needs to be set in the Counter:
dustin
Forum|alt.badge.img+36
  • Dec 15, 2022 2:04 PM UTC
Probably a few ways to get this result, but this should work.
  • Aggregate based on Attribute1 and Attribute2
  • Sort based on Attribute1 and Attribute2
  • Counter gives the aggregated features the GROUP_ID
  • Deaggregate, which retains the GROUP_ID on the individual features.
  • Dec 15, 2022 2:14 PM UTC
dustin
  • Dec 15, 2022 2:16 PM UTC
I really did😀 In the Counter, you can specify the Count Start with '1'.
dustin
  • Dec 15, 2022 2:29 PM UTC
