How to fix breaks in polylines?
  • Nov 22, 2022 6:21 AM UTC
  • 10 replies
  • 250 views
johnk
I have a contour dataset which has been clipped incorrectly and has produced errors in the resulting polylines. There are numerous breaks in it, for example, the 0.8m contour line (see attached image) and I would like to join these together. A straight line is fine. I have tried Snapper and LineCombiner with no success. Any suggestions would be great!
Thanks.
itsmatt
Forum|alt.badge.img+48
  • Nov 22, 2022 7:21 AM UTC
Try the LineBuilder - This should do what you want. The lines will need to be ordered correctly though
"Connects input point features in the order they enter, forming linear or polygonal features." you'll need to group by your contour elevation.
The will probably create some issues when you have contours of the same elevation which should not be connected. That's another can of worms though.
johnk
  • Nov 22, 2022 8:15 AM UTC
Hi @virtualcitymatt​ thanks for your reply! Well the lines needing the breaks to be joined are actually just one feature... As in a feature is one line with a series of breaks in it which need filling.
I have used LineCombiner to effectively split these into separate features, but unsure where to go with that.
  • Nov 22, 2022 8:42 AM UTC
What about the Snapper did not work? I'd make sure to use the following settings:
imageAlso very important to remember that the snapping distance is relative to the coordinate system of the input. Meaning that if the the incoming data is in degrees, the snapping distance must also be specified in degrees.
itsmatt
  • Nov 22, 2022 8:48 AM UTC
Ahhh interesting, the you can create an ID for each group of lines, use a Deaggregator to split them and then use the LineBuilder to connect them together (you can then group by the ID). You don't need the LineCombiner here. Again, this assumes that all line segments are ordered correctly.
itsmatt
  • Nov 22, 2022 8:53 AM UTC
The Snapper had a bad habit of forming undesired loops. A potential improvement could be had there
johnk
  • Nov 22, 2022 11:08 AM UTC
Ah ok great this works perfectly for some of them. But others it doesn't as the lines when deaggregated are not in order. An example of one not being in order hereContour error
johnk
  • Nov 22, 2022 11:09 AM UTC
Thanks @david_r​, as @virtualcitymatt​ says, often it created these loops in the polyline - even with the settings you suggest
hkingsbury
Forum|alt.badge.img+73
  • Nov 22, 2022 8:57 PM UTC
You could try extracting the dangle nodes (nodes with only one connection) then using a neighbour finder, find which dangle nodes need to be connected and use the result to fill in the gap(s).
It won't improve the vertex order, but it should help get you a (visually) continuous line.
johnk
  • Nov 23, 2022 5:42 PM UTC
Thanks @hkingsbury​ - do you have a way you would do this?
hkingsbury
  • Nov 23, 2022 8:17 PM UTC
Here's an example, its pretty rough and can be refined a bit, but should give you the general gist of it
