How to extract oriantation under "Area: IFMEPolygon"
  • Oct 4, 2020 8:54 AM UTC
  • 10 replies
  • 97 views
"Orientation" is desucribed under "Area: IFMEPolygon".
Could you tell me how to extract it to attribute, or the way of filtering by the "Orientation" value.?
danilo_fme
Forum|alt.badge.img+58
  • Oct 4, 2020 10:55 PM UTC
Hi @bigapplerizzi19​
Please - could you share us the image or sample data?
Thanks in Advance,
Danilo
Hello @danilo_fme​
Thank you for your reply.
Attached is a image that show the "Orientation" that I want to extract or use for filtering.
Best Regards,
nielsgerrits
Forum|alt.badge.img+67
You can use the OrientationExtractor to get this as an attribute.
Hello @nielsgerrits​
valid_surface_orientation" is extrated.In my case shown in the previous images, the value extracted by OrientationExtractor is "valid_surface_orientation".
I expect "Right Hand Rule" is extrated.
Could you tell me the solution?
Best Regards
nielsgerrits
Best Regards
From the documentation:
Surface
If the input is a surface geometry, where all parts of the surface are consistently oriented, the attribute will be set to the value valid_surface_orientation. If the parts are unoriented or inconsistent, the attribute will be set to the value no_orientation.
It looks like you won't get "right_hand_rule" out of the OrientationExtractor without taking it apart. I think you need to extract the individual geometries and go from there. Not sure how, and without a sample it's hard to check.
danilo_fme
  • Oct 6, 2020 12:42 PM UTC
Best Regards
Could you share you sample data?
Hello @danilo_fme​ ,
Sorry, it is difficult to share the data. Because it is intermediate data of some transformers.
You can find a attached sample data.
Orientation of two wallsurfaces of this modle are "Right Handed Rule".
I would like to change those to "Left Handed Rule"
Let me know if you need any additional information.
  • Mar 10, 2022 8:48 AM UTC
For anyone else with the same problem I managed to do it by deaggregating the feature and converting the faces to polygons. Then the resulting attribute value describes whether the feature in question uses left_hand_rule og right_hand_rule, instead of returning "valid_surface_orientation"
Hope this helps someone.
