How to extract (key,value) elements from multiple xlm files and turn them into a flat table?
  • Mar 5, 2021 2:20 AM UTC
  • 194 views
aguan
Forum|alt.badge.img+11
I have multiple xml files, each with the same structure as shown below:
 <Metadata>
   <MDI key="MAXIMUM">9</MDI>
   <MDI key="MEAN">4.2018685725509</MDI>
   <MDI key="MINIMUM">0</MDI>
   <MDI key="STDDEV">2.3097856863945</MDI>
  </Metadata>
I want to create a table with using the MDI Keys as the column names, and the element values as the rows from all the xml files, as illustrated below. Can do a single file with AttributeTransposer, but could not figure out a simple way to load all the files together, feeling awkward with limited knowledge of FME XML transformers. Need some expert help here.
 Capture
Best answer by ebygomm
If you have a list of the filepaths, you can use an XMLXqueryExtractor, use the filepath as your XML input with XML Input set to XML File then
for $m in //MDI
return fme:set-attribute($m/@key, $m/text())
Expose the MAXIMUM, MINIMUM,STDDEV & MEAN under the Attributes to Expose Parameter
Forum|alt.badge.img+54
  • Mar 5, 2021 9:03 AM UTC
for $m in //MDI
nielsgerrits
Forum|alt.badge.img+67
for $m in //MDI
Learned something new today :)
aguan
  • Mar 6, 2021 1:38 AM UTC
for $m in //MDI
@ebygomm, brilliant, works like a charm. I wish I knew XQuery more. Thanks a bunch.
