How to extend and trim
  • September 22, 2021
  • 110 views
vijay16vali
f.kemminje
Forum|alt.badge.img+11
Did you try Use snapper transformer​
danilo_fme
Forum|alt.badge.img+57
Hi @vijay16vali​
As @f.kemminje​ wrote above, the transformer Snapper is good tip to extend your line.
For trim action you can split the line with LineOnLineOverlayer and calculate the lenght on lines.
After you can filter the microlinies using the transformer Tester.
Thanks in Advance,
Danilo
