How to create published parameter with a choice of FME Feature Attributes
  • Aug 25, 2020 12:23 PM UTC
  • 56 views
robinb
Hello all,
I am attempting to create a published parameter within a custom transformer that prompts the user to state which is the primary key field from the input database table.
Is there a way of creating this published parameter, whereby it provides the user with a list of all available feature attributes (i.e. database fields) from their input table, so that they can select which is to be nominated as the primary key?
##Update, it looks like I have managed to answer my own question - you can use the Type: AttributeList within the the published parameter to achieve this
As a follow up question, does anyone know how I can then use the user chosen parameters within a stringreplacer transformer to update a field?
Basically, using the data example below, if the user, via published parameters, the user has nominated colA as their primary key field, and nominated colB via another published parameter, is there a way of then using the values within these fields to then replace colA as a concatenation of the two field values?
From this:
To this:
I have tried using the StringReplacer as per below but it is writing out as blank
Thanks in advance,
RB
siennaatsafe
Forum|alt.badge.img+12
Hi @robinb​ ,
It's great you were able to solve the first part of your problem. Unfortunately, I don't think the screenshots of your data came through so it's hard to tell what you're starting with and what your end goal is. Would you mind trying to attach them again?
