How to create empty shape using an attribute as name
  • Oct 16, 2020 12:51 PM UTC
  • 89 views
Hello there,
I need to create empty shape files, using an attribute as directories and files names.
For now I always have an object( with "NULL" attributes values) in each tables.
Any one have a solution ?
jdh
Forum|alt.badge.img+41
  • Oct 16, 2020 2:35 PM UTC
Is the schema always the same? If so, you could probably make an empty shapefile in arcgis or qgis and the use a filecopy writer to rename it.
Forum|alt.badge.img+54
  • Oct 16, 2020 3:05 PM UTC
If your schema's aren't identical, you can write the shapefiles you are currently creating to a temporary location then copy them and delete the features using arcpy to your final location
Thanks for answers !
I didn't know the filecopy writer. I'm looking on it and I guess that will be my solution. I'll try it this monday.
