How to convert lines to points
  • Nov 26, 2022 7:51 PM UTC
  • 1983 views
spiderman
Forum|alt.badge.img+7
Hallo ,
i have lines data and I have only start point and end point of line .but I would like to get all geometry of points from start till end point.
,so I have used chopper to convert lines to points but my problem .I am not sure ,how could i add all geometry of points from start till end point in new attribute for the same id of line .
FME 2021
Thanks for help .
Best answer by caracadrian
One way would by creating unique ID's for lines before Chopper, putting x,y,z in attributes then aggregating with GroupBy on the unique ID and generating a list with the coordinates.
Another way would be GeometryExtractor. It simply creates an attribute that stores the geometry as a whole. OGC Well Known Text would be one of your better choices.
GeometryExtractor
caracadrian
Forum|alt.badge.img+23
  • Nov 28, 2022 5:53 AM UTC
GeometryExtractor
