How to convert lines to many points ?
gogopotter90
Forum|alt.badge.img+13
Hello ,
how could I convert lines to too many points ?
i have used chopper with max vertices 1
but it seems to me a little points that I get .
i would like to have too many points as possible for each line .what should I do ?
thanks kn advance
FME 2021
Forum|alt.badge.img+39
  • April 19, 2023
The chopper will only give you points wherever there is an existing vertex. If you want more points you could try a densifier on the line before chopping
gogopotter90
  • April 19, 2023
Thanks ,
i have question relates to densifier .how could I divide the lines to same distance has small values between each point .which mode should I use ?
