How to convert file geodatabase to arcsde ?
  • Jun 21, 2023 2:53 PM UTC
  • 43 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
thanks in advance
FME 2021
hkingsbury
Forum|alt.badge.img+73
  • Jun 21, 2023 9:00 PM UTC
SDE is basically a GDB on a database.
You need an existing SDE environment setup (And connection file). It's then just a case of setting up your SDE writer just as you would a GDB writer
