How to connect some points together without intersect other lines ?
  • Nov 6, 2023 7:57 PM UTC
  • 144 views
soly
Forum|alt.badge.img+3
Hello ,
i have some points at the same line
each two point has the same attribute .
i would like to connect each point that has same id together
So I think I can use line builder with group by id .how
but how to connect each two point without the line intersect with other points ?
as my phone ,
point 1 and point 4 has the same id
but if I connect 1 and 4 together so it will create line intersect or overlap on other line between 2 and 3
2 ,3 has same id
1,4 has same id
what should I do to create line between 1,4 and other between 2,3 ? The line should cross but not intersect because I would like to use network topology calculator later .
fme 2021
ctredinnick
Forum|alt.badge.img+22
  • Nov 7, 2023 7:52 AM UTC
If you are using a LineBuilder with a GroupBy, then the line geometry it creates will connect all the points in each group. All the groups are separate, there will be no intersection that a network topo calculator could recognise, except if two groups share the same point.
If you want to 'clip' out segments of these lines if they pass other points, then use a PointOnLineOverlayer, all points vs all lines, on the lines add a list of point IDs they touch, and then on the output exclude any new segmented lines if that list doesn't contain at least one point ID from its original group.
