how to connect FME Server to existing license server?
  • May 23, 2022 11:57 AM UTC
  • 46 views
parke372
Forum|alt.badge.img+11
I have installed FME desktop and server, my organization has a license server that i was able to define for the desktop client, but, i am unsure how to configure the FME server instance to that license server?
Is it not meant to work that way?
Thanks,
Jared
Forum|alt.badge.img+63
It is not meant to work that way, FME Server uses Safe's own licensing. You should have received a serial number, if you go to the System Configuration -> Licensing page in FME Server you can enter it there to register it.
