¿How to call an specific table from an OPEN API file geodatabase in FME SERVER?
  • Sep 15, 2021 6:58 PM UTC
  • 48 views
armando_amador
Forum|alt.badge.img+5
Hi Everyone!
I have a repository in FME Server where I stored an OPEN API fgdb, then I'm running a Workspace but I cannot map the specific table where I want to extract data to process.
Any help?
Thanks!!!
rahulsharma
Forum|alt.badge.img+12
Hi @armando_amador​
I am unclear on the acutal issue, if you are trying to set up Reader Table List , you can accomplish that via publishing parameters.
You can create a choice parameter with the value set to the table names.
e.g. If you have the following 4 tables in your geodatabase Airport, BusRoutes, Metrorail, BusStops
ChoiceParameterNow add the reader to the workspace
Do not select any Table, on the reader dialog, select Dynamic
Once the reader is add, In the Navigator Windows --> Reader --> Feature type to Read
Right-click and delete the publish parameter
Again right-click and "Link to Parameter" and from the drop-down, pick the parameter created above.
AssignParamIf you are trying to access the Writer FileAPI location on the FME Server repository.
For this, you will have to use publish parameter $(FME_DATA_REPOSITOR)\\foldername\\Output.gdb
