How to calculate the last day of previous month in FME?
  • Feb 21, 2023 10:28 AM UTC
  • 514 views
Hi guys, I am fairly new in FME but have been working in a workflow and got stuck on something that might be simple solution for some of you. I need to be able of calculating the last calendar day of previous month from today's date.
So today being 21/02/2023 my result should be 31/01/2023.
Can you please advise how I can do this ? I have been really struggling to do this and have attempted DateTime Calculator transformer.
Best answer by ebygomm
Assuming your date is in an FME format, i.e. 20230221, take the first 6 digits and add 01 to get the first day of the month, then minus a day in the DateTimeCalculator. Use a DateTimeConverter first if you need to get the date in FME format
Forum|alt.badge.img+54
  • Feb 21, 2023 11:27 AM UTC
  • Feb 21, 2023 1:25 PM UTC
Absolutely brilliant, it worked .Thank you so much !
