How to append a field based on a comparison of string values when naming conventions differ
  • Jan 5, 2021 8:33 PM UTC
  • 5 replies
  • 99 views
bcoveney
Hi there,
I am trying to find a simple way to append an asset code to a list of facilities. I am running into trouble because there is no standardization of naming for these facilities leading to slightly different names (short forms, etc). I have a master list that I would like to use to compare and append the asset code to when given tabular data that 1) does not include the code and/or 2) does not match the master list naming convention.
I can't wrap my head around which transformer to use and would appreciate the help!
Best answer by markatsafe
@bcoveney​  Looks like a fuzzy matching problem. Try the FuzzyStringCompareFrom2Datasets that is available on the FME HUB.
@bcoveney​ Do you have an example that would help explain the problem?
bcoveney
  • Jan 5, 2021 9:26 PM UTC
Here are snippets of the data tables I am working with. First is the master list I referenced, followed by an example of the data I receive. As you can see, the naming convention for facilities is different - not shown are instances where a shortened name is expanded to its full name or vice versa. Essentially, I want to compare tabular data and attach the 4 digit code to the dataset missing it.
CapturemsCaptureI appreciate your response!
  • Jan 5, 2021 9:40 PM UTC
Fuzzy should do the trick as @Mark Stoakes​ mentions. For future reference, you will want to manipulate the data a bit before you do that. The closer you get them to begin with the better off you are in terms of getting a closer match.
Example of manipulating the data;
StringReplacer - replace Public School with PS
StringReplacer - strip off (FDK)
StringReplacer - replace '-' with ' - ' to split the dashed vales
You don't have to go overboard with the initial cleanup, but it's always a good idea to do some to save you a headache.
bcoveney
  • Jan 6, 2021 2:41 PM UTC
I plan on working off of what @Mark Stoakes​ suggested. I did think ahead to clean up the data to ensure an easier match - glad I was on the right track at least!
