How do you merge features based on an attribute value in one feature that matches a different attribute in another?
  • May 3, 2021 2:37 AM UTC
  • 51 views
larue
Forum|alt.badge.img+12
I'm using the FuzzyParallelLineFinder and want to aggregate the line pair geometries that were identified. Then, turn into a CAD block with unique ID, and/or WKT format in a spreadsheet.
 The way it identifies parallel lines is : _line_id of one feature = _match_id of another and vice versa.
I attached a Dynamo script picture that does what I am looking for.
Thanks,
@larue​
Best answer by larue
I used duplicate outputs with one going through attributerenamer before connecting to Aggregator, then filtering out duplicates by geometry. By changing one of the id attributes to the other, it could be grouped.
larue
  • Dec 22, 2021 5:41 AM UTC
