How do I add alias names to a table. I have a lookup csv file with over 180 entries so don't want to add them in manually
  • Aug 12, 2020 12:09 AM UTC
  • 61 views
gisgeek
Forum|alt.badge.img+9
How do I add alias names to a table. I have a lookup csv file and a table with over 180 columns so don't want to add them in manually. I just don't know how to get the alias names into my table
nielsgerrits
Forum|alt.badge.img+67
I think you want to add aliases to columns in an existing ESRI featureclass? The best way to go is probably using Python. See ESRI's documentation.
import arcpy
arcpy.AlterAliasName('c:/city/Boston.gdb/SnowReport', 'Snow Report')
If you want to add aliases to a new featureclass you can use this FME article.
