How can write a CityGML 3.0 file , what i need?
  • Apr 27, 2021 11:12 AM UTC
  • 6 replies
  • 224 views
itsmatt
Forum|alt.badge.img+48
  • Apr 27, 2021 11:21 AM UTC
Check out this github repository
https://github.com/tum-gis/ifc-to-citygml3
CityGML is not yet officially released so there is no version 3 yet in the FME CityGML writer
  • Apr 27, 2021 7:48 PM UTC
Thanks for your answer.
I've seen it, I'm trying to create a CityGML 3.0 file but it does not work, in fact, I probably have a problem with it gml_parent_id.
While with FME Inspector the 3D model appears normally.Screenshot 2021-04-27 224358Screenshot 2021-04-27 224224
itsmatt
  • Apr 30, 2021 5:51 PM UTC
Check the log file for warnings. There might be some hints in there​
  • Nov 17, 2021 8:50 AM UTC
I think CityGML 3.0 has been officially released.
https://www.ogc.org/standards/citygml
Do you plan to support CityGML 3.0 in FME 2022? > Safe
See also here.
https://community.safe.com/s/idea/0874Q000000cTy1QAE/detail
itsmatt
  • Nov 17, 2021 9:41 AM UTC
See also here.
Let's hope so! FME support would really help users move to the new standard
kailinatsafe
Forum|alt.badge.img+24
Hello @virtualcitymatt​ & @Takashi Iijima​ , fairly certain development is starting to work on this now. Not sure if it will make it into 2022.0 or 2022.1 however.
Note* we do have limited support for R/W CityGML3 right now, with the GML R/W uing CityGML3 schemas. Also, we don't support appearances yet for this. Hope this helps, Kailin.
