I want to upload several pdf maps to AGOL, which I am downloading from Sharepoint. How can I upload over 20 pdfs on AGOL using ArcGISOnline Connector transformer?
Best answer by j.botterill
Hi jaygrg, yes it should be feasible. You would need to pass all 20 into the arcgisonlineconnector with upload action. The file parameter would be an attribute value of the filepath. So before the connector, place a reader or feature reader with format = directory file path
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/path/path.htm
then in the connector use the @value(path_windows) for File
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
