How can I upload a test workspace that tests an Authorization Code flow Web Connection?
  • Sep 9, 2023 3:27 AM UTC
  • 0 replies
  • 37 views
jared_bloch
I am trying to publish a new Web Connection to FME Hub that uses OAuth 2.0 Authorization Code Flow. My test workspace fails when FME Hub tries to run the test workspace. I suspect it is because the Authorization Code flow requires user interaction. Is there any way to successfully test this workspace that calls the Web Connection I am trying to test?
