How can i read features with a shared UNC-Path and the Directory and File Pathnames Reader?
  • Dec 27, 2022 8:17 AM UTC
  • 178 views
resch
Hello everybody,
we have a problem with the Directory and File Pathnames Reader.
There is an UNC-path: \\\\[server]\\X$\\[directory]\\[directory]\\[directory].
The user has access to the (last) directory and also rights to write. This has been checked.
If we use this UNC-path with the Directory and File Pathnames Reader zero features will be read. There is no error, just zero features.
It works (with same settings except the path) when the path/directory is connected as network drive. But this is undesired.
Has anybody an idea how this with the blank UNC-path works?
We are using the FME Desktop (and FME Server) version 2020.2.0.0
Thank you very much in advance!
EDIT:
it works with a blank path filter and when subfolders are excluded:
imageBut we also need the informations which are in subfolders.
When it's set to "yes" we run in the same problem (as described above) again.
Is it possible that FME needs here special or deeper permissions for the folders/folder-hierarchy?
Still thank you! 🙂
stefanh
Forum|alt.badge.img+8
  • Jan 4, 2023 10:58 AM UTC
This shouldn't be a problem.
Do you get a specific error?
Did you try to put the UNC-path in between quotation-marks (")?
resch
  • Jan 25, 2023 12:16 PM UTC
hello stefanh,
thank you!
yes, we checked this, but it makes no difference.
