How can I control polygon vertex order
  • Sep 16, 2021 7:12 AM UTC
  • 5 replies
  • 149 views
btl
Forum|alt.badge.img+12
I have some simple polygons in a shapefile where, for texturing purposes, it is important where the first edge is compared to other features. I created a workspace that explodes the polygons and reorders the edges based on the other features. At this point everything looks good.
However, when I use AreaBuilder to rebuild the polygons, on some (most are ok), the edge ordering is not maintained. How can I keep the edge order I want?
EdgeOrdering
Best answer by itsmatt
hmm, have you tried the area builder with just the points (rather than the lines). That would be something I'd try.
itsmatt
Forum|alt.badge.img+48
  • Sep 16, 2021 8:59 AM UTC
  • Sep 16, 2021 9:54 AM UTC
You could also try the LineCloser, or simply the GeometryCoercer set to fme_polygon.
btl
  • Sep 16, 2021 9:59 AM UTC
Thanks, this works - although of course the AreaBuilder doesn't accept points so I used the LineBuilder instead.
itsmatt
  • Sep 16, 2021 11:50 AM UTC
I think the problem is that he has 4 line segments and the AreaBuilder is messing up the order which is weird.
  • Sep 16, 2021 12:48 PM UTC
Ah yes, I see now. It would be necessary to use a LineJoiner first, to try my suggestions.
I agree that the mixed up order is weird. I've seen something similar when writing and re-reading the same object from SDE, interestingly enough.
