How can I calculate value of Attribute as shapefile name in FME?
  • Jul 22, 2021 3:48 AM UTC
  • 109 views
khaphan
I have amount Shapefiles and I want calculate value of attribute as shapefile name. Who can help me? Thanks so much!
Best answer by caracadrian
Your question is a bit ambiguous.
If you need the name of the file that you read you can expose fme_basename on the reader Format Attributes tab.
Reader fme_basenameIf you need to write your features to a controlled custom filename set Shapefile Name on the writer to an attribute or a concatenation of attributes via Text Editor.
Writer filename by attribute
caracadrian
Forum|alt.badge.img+23
  • Jul 22, 2021 4:50 AM UTC
khaphan
  • Jul 22, 2021 6:33 AM UTC
Thank for your support. I setup Format Attribute at Reader and Writer so It worked. 😁
