How can calculate angle between lines ?
  • Nov 19, 2020 4:57 PM UTC
  • 731 views
checcosisani
Forum|alt.badge.img+14
Hi
I need to calculate the angle between lines in a network (red angle in the picture) I mean the angle between the side road and the main road
Thx
Francesco
DanAtSafe
Forum|alt.badge.img+23
  • Nov 19, 2020 6:00 PM UTC
Hi @checcosisani​ I don't see any picture, but if I'm imagining this correctly you can get the angles of each line at a node if you 'Generate List From Input Edges' on the Nodes in the TopologyBuilder. The list attributes will be sorted by angle, increasing counter-clockwise from East. The angle between lines (first segments from the node) can be calculated something like this: (@Value(edges{1}.fme_arc_angle) - @Value(edges{0}.fme_arc_angle) )
checcosisani
  • Nov 19, 2020 7:51 PM UTC
Angle
