Hi Team, How I can change the depth resolution in SnS workflow? When I model the horizons I see many bores where the markers are collocated. When I select "Edit Well Markers" all looks good.
  • Mar 30, 2022 8:06 AM UTC
  • 31 views
The problem is where the markers are closer than approx 10 m each other. Gocad tells me these are collocated markers. How is it possible to fix? I do not want to discard the bores from the model.
danminneyatsaf
Forum|alt.badge.img+13
Hi @blackswan876​, unfortunately at the moment we do not have support for reading or writing the GOCAD Mining Suite format. I do however recommend adding your vote and any comments to the idea posted here! https://community.safe.com/s/bridea/a0r4Q00000HbrFbQAJ/add-3d-gocadskua-file-format
If you are already able to read your data in FME, may I ask what format reader you are using?
