Hi, is there any template to read IEC CIM/XML format file?
  • Jun 19, 2019 2:28 PM UTC
  • 56 views
@ikamalakar Our XML reader should be able to interpret the CIM/XLM for you. It might need a degree of reconstruction since CIM is such a normalized data model. If you have a sample dataset that you can share, we could help you try and unravel it. If you can't make the CIM data public you can send it to me <mark@safe.com>
