Hi! I have a large workspace where I need to update a table with a status message. This means that I need to update the tables status even if no features are routed to the feature writer.
  • Feb 1, 2023 8:17 AM UTC
  • 58 views
essb
Fme server
desktop version: 2022.1
But if no features reach the writer then I get no summary output. In what way can I solve this dilemma?
image_fwThe image I provided is not of the workspace itself, but it shows the problem.
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use the NoFeaturesTester from the hub.
essb
  • Feb 1, 2023 9:23 AM UTC
Thanks nielsgerrits, I will look at that one.
I think I solved my own problem now. There are probably many solutions but this seems to work.
If I use the creator from the beginning of the workspace and I merge it in the end then I can do a check to see if features are written or not.image_fw_s
ctredinnick
Forum|alt.badge.img+22
  • Feb 1, 2023 10:05 AM UTC
The initiator port of a FeatureReader includes a matched_records attribute which is the count of how many features are read. Depending on the process, you can sometimes just test on this if anything matched.
