Hi everyone, I've got to convert waypoint files to GPX files. I also need to convert txt to GPX. Please let me know if there is a work instruction for either conversion. Kind Regards, David
Best answer by hkingsbury
david_lyons wrote:
I cannot add the WPT. file But this is the same version in txt.
Have a look at the attached .fmw
Reads in the text file using a text file reader (could also use CSV reader if there was a header line) then splits each row into each attribute (splits on a comma) then assigns the list element to an attribute (just lat/long in the example) then creates a point and writes it to gpximage
hkingsbury
Forum|alt.badge.img+55
  • March 6, 2022
Are you able to supply some examples of the two input files?
The gist of the process(es) will be to read the data in, create the required geometries, then usining the GPX writer, write the geometries out to the required file(s)
hkingsbury
  • March 7, 2022
