Hello, I need to uninstall tjhe earlier version of FME 2017.0.1.1 but the uninstaller in windows requires the fme_eval.msi file which I do not have anymore. Where can I get it?
Best answer by geo_b
jaro wrote:
Hello,
No, unfortunately I couldn't solve it. It was one of the reasons which forced me to buy a new PC and do a fresh installation. So I didn't work on the problem anymore. But I understand how annoying it is.
Thanks for the reply @jaro . In the end I was able to download the matching version from the past versions page https://www.safe.com/support/downloads/#past-versions, then renamed the installer as fme_eval.msi. This was sufficient enough to perform the uninstall. Posting the update here in case it helps someone else down the road.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
