Hello, I need to uninstall tjhe earlier version of FME 2017.0.1.1 but the uninstaller in windows requires the fme_eval.msi file which I do not have anymore. Where can I get it?
  • Aug 27, 2020 11:55 AM UTC
  • 5 replies
  • 111 views
jaro
Best answer by geo_b
Hello,
No, unfortunately I couldn't solve it. It was one of the reasons which forced me to buy a new PC and do a fresh installation. So I didn't work on the problem anymore. But I understand how annoying it is.
Thanks for the reply @jaro​ . In the end I was able to download the matching version from the past versions page https://www.safe.com/support/downloads/#past-versions, then renamed the installer as fme_eval.msi. This was sufficient enough to perform the uninstall. Posting the update here in case it helps someone else down the road.
  • Aug 27, 2020 12:06 PM UTC
Maybe try reinstalling FME 2017 to the same folder, then uninstall after.
You can find FME 2017.0.1.1 here: https://www.safe.com/support/downloads/#past-versions
  • May 19, 2021 3:10 PM UTC
Hi @jaro​ did you ever figure this out? I tried recommendation by @david_r​ but I am unable to install using the same version, and I get the same error about the missing fme_eval.msi file. I also tried installing a new version over the top but the installer fails because it is unable to uninstall the previous/existing version.
jaro
  • May 19, 2021 7:24 PM UTC
Hello,
  • May 19, 2021 11:20 PM UTC
Hello,
jaro
  • May 20, 2021 7:11 AM UTC
Hello,
Woow, good idea, congrats!
