Hello! I am using a Server App with FME Server to generate MsWord reports. I have been getting this error: Microsoft Word Writer: Aborting translation: Not authorized to access destination file.
  • Apr 21, 2021 12:17 AM UTC
  • 6 replies
  • 99 views
The error ends with "Please ensure that destination file is closed and check destination filepath" - most reports are generated but the very large ones fail (160 mb). Periodically these will work without an issues. Any help figuring this out would be greatly appreciated. Thanks!
kailinatsafe
Forum|alt.badge.img+24
Hello @bibold​ , what service is the Workspace App set to run under? (eg. DataStreaming, DataDownload, etc). Here to help, Kailin.
  • Apr 21, 2021 6:21 PM UTC
It is running under Job Submitter. It runs the workspace, creates the Word document and the user gets the document from a file share. Thanks for helping, Kailin!
novo
Participant
  • Participant
  • Jan 27, 2023 3:18 PM UTC
I ran into this issue in the last few days, and it turned out that the output file name had replaced white spaces with <space>. When I removed the spaces and replaced with underscores in my parameter that eventually became the file name it ran with no issues.
kailinatsafe
Hello @novo​, would you be able to share a sample workspace, where I can try reproducing the issue? Also, what version of FME Desktop/Server are you running? Happy to help, Kailin.
donegal_david
Participant
Hi, has anyone found a solution to this? I'm coming up against a similar issue since I've upgraded to FME Flow 23.1 Everything was working fine in 2022.1. I've tried re-publishing the workspace etc. from FME Form. However, I'm having no luck in finding a solution.
Thanks,
David.
  • Oct 26, 2023 4:01 PM UTC
Thanks,
David.
@donegal_david​ , I was creating these on a shared drive and ended up resolving the issue by creating them on the FME Server box and then moving them to the shared drive using a PythonCaller.
